VAFC II
Old Mar 4, 2007 | 10:20 AM
freshs2k's Avatar
Default VAFC II
just installed my vafc II. I have the pnp harness from vtec frog. The vafc is on n running but its flickering when i get on the throttle. any ideas? any help would be appreciated.
Old Mar 4, 2007 | 05:34 PM
freshs2k's Avatar
anyone? it doesnt seem like its gettin constant power. vtec will kick in at different times sporadically.
Old Mar 4, 2007 | 06:23 PM
negcamber's Avatar
Double check to make sure the harness is fully plugged in at both the ecu and at the VAFC...sounds like it is not making good contact somewhere along the way.
If all the connections are good, find someone else in your area with a working VAFC and plug yours in its place. See if it has the same problem. If so, then the VAFC has a problem. If it works fine in the other car, then your harness has a problem.
Also make sure all the corrections are set to zero until you can get it tuned.
Old Mar 4, 2007 | 07:20 PM
viets2k's Avatar
Mine was wideband o2 tuned and dynoed with I/H/E(test-pipe), Today i just swapped the stock exhaust back on. So, can i keep the same setting or playing with the setting a little bit and still be safe or should i set everything back to 0 correction and get it re-tuned?
Old Mar 4, 2007 | 07:27 PM
negcamber's Avatar
Viet...probably best not to hijack this thread. I think you started one of your own with this question. I'll respond there.
Old Mar 4, 2007 | 07:53 PM
viets2k's Avatar
OOOp, my bad. Thanks negcamber.
Old Mar 5, 2007 | 03:29 AM
freshs2k's Avatar
thanks! ill check that out.
Jack_in_the_Box
Sep 26, 2008 12:12 PM
freshs2k
Mar 5, 2007 04:27 AM
WalkingDrunken
Nov 16, 2004 10:30 AM
WalkingDrunken
South Florida
Nov 16, 2004 10:23 AM
mxt_77
Sep 1, 2004 01:06 PM
