valve adjusment
at 64k miles, i would recommend getting it done regardless. also check the belts and change water pump and thermostat while you are at it. these are cheap and easy to do but can cause you trouble if not done
The s2k only has one belt. In the 4 years I've been working on s2k's, I have never seen a single bad belt, water pump, or thermostat. And what does that have to do with a valve adjustment?
