valve adjusment
Old Aug 1, 2007 | 10:06 PM
FreerunSquad_s2k's Avatar
Default valve adjusment
so i herd on s2000 your suppsoe to do valve adjusment...im at 64k miles....and dont kow if the perviosu owner did one,,so yea..hlep please
Old Aug 1, 2007 | 10:12 PM
tekstar's Avatar
do you hear a ticking noise when you drive? that's usually a hint that you need an adjustment. i got mine done at 60k and it helped.
Old Aug 1, 2007 | 10:23 PM
Hoa's Avatar
Hoa
at 64k miles, i would recommend getting it done regardless. also check the belts and change water pump and thermostat while you are at it. these are cheap and easy to do but can cause you trouble if not done
Old Aug 2, 2007 | 03:05 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The s2k only has one belt. In the 4 years I've been working on s2k's, I have never seen a single bad belt, water pump, or thermostat. And what does that have to do with a valve adjustment?
Old Aug 2, 2007 | 04:38 AM
Hoa's Avatar
Hoa
it has nothing to do with valve adjustment. i suggested it since there is no record of what the previous owner did on the car
stefluva
Sep 7, 2004 08:54 PM
Gernby
Dec 6, 2002 04:13 PM
