Valve adjusment noise ! Does it normal ?
Old Mar 1, 2014 | 02:46 AM
Tboy's Avatar
Default Valve adjusment noise ! Does it normal ?
Hi guys
I noticed that my car has this noise whenever i started the car !
Does it normal noise for the s2000 or something wrong with it ?
If my engine making this noise so can i keep on running it or not ?
Please check out the video below to listen to the noise !
Helps will br appreciated
http://m.youtube.com/watch?v=AYwGKAkJJME
Old Mar 1, 2014 | 02:52 AM
dwight's Avatar
How long have you had the car?
Is this noise new?
Did you do a valve adjustment?
Old Mar 1, 2014 | 03:12 AM
Tboy's Avatar
i did have the car for almost 1 year
its done 120.000 km
haven't done any valve adjustment yet and not sure about the last owner had done or not !
is this normal if i just leave it like this or i can't keep on running it ?
Old Mar 1, 2014 | 03:15 AM
Tboy's Avatar
i haven't heard this noise before or wasn't noticed since i got the car
Old Mar 1, 2014 | 06:14 AM
franky's Avatar
It's pass due for a valve adjustment. I wouldn't want to continue driving it until the valve adjustment is done.
Old Mar 1, 2014 | 06:22 AM
zeroptzero's Avatar
I thought that the noise got louder as you approached the Timing Chain Tensioner area of the engine (passenger side). That part could be starting to fail, but you should do a valve adjustment either way.
Old Mar 1, 2014 | 07:08 AM
Stock00S2K's Avatar
I hear a symphony on different noises, most of which sound like a typical S2K engine. Can you elaborate on which noise sounds suspiscious?
Old Mar 1, 2014 | 07:55 AM
mambo's Avatar
It sounds like TCT noise to me... you could try doing another valve adjustment to rule it out, or just get an aftermarket TCT and see if that fixes the noise. Chances are, it's going to fail anyway
Old Mar 1, 2014 | 09:56 AM
bottleboy's Avatar
when i got my car everyone taught it was valves, jump on the forum found that the tct get defective. changed it out for heavy duty one and the noise whent away
Old Mar 1, 2014 | 01:01 PM
mattiouti's Avatar
+1 for timing chain tensioner. It's not the first time I've heard that
morphenyou
Sep 29, 2018 10:33 PM
JSchwieb
Jun 30, 2018 04:32 AM
Vangelis
May 21, 2018 05:48 PM
francor10
Jun 23, 2012 10:48 PM
marcucci
Jul 2, 2001 06:02 PM
