Valve Adjustment question
Old Aug 20, 2005 | 05:45 AM
SpaZilla's Avatar
Default Valve Adjustment question
Ive done tons of valve adjustments on my B series motors, do i still slide the feller guage between the cam lobes and rocker arms, or am i sliding tbe feelr between the lock nut?
Old Aug 20, 2005 | 10:28 AM
JDMwhore's Avatar
Between the adjustment screw and valve retainer
Old Aug 20, 2005 | 01:17 PM
CoralDoc's Avatar
Actually, it's between the adjustment screw and the valve stem, just above the retainer. This is found on the other side of the cam follower from where the lock nut is located.
Old Aug 20, 2005 | 04:07 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
What they said
PIC that I had from back in the day, for clarification
Old Aug 21, 2005 | 06:47 AM
SpaZilla's Avatar
thanx guys ill be doing it shortly an dloks alot easier than doing the old b series motors
Old Aug 21, 2005 | 08:44 AM
SpaZilla's Avatar
well as I went to adjust my valves i noticed that i can tap the intake valves at least 1/16 th of an inch (up down). All 8 intake valves but cant do that on the exhaust side. Now I dont know how possible it would be that I bent some valves, ive never over revved the motor, but i did buy this car 2 months ago used with 24,000 miles. The idle doesnt stumple and does drive fine. Im just curious to know that this is normal? I will do a comopression check later on, what is the ideal compresion psi for this motor, 240 or higher?
Old Aug 21, 2005 | 10:15 AM
CoralDoc's Avatar
You can only adjust valves on one cylinder at a time! Look at the cam lobes - when both the intake and exhaust cam lobes are angled upward and outward from the centerline of the engine by about 45 degrees, the valves can be adjusted. You must then move the engine before adjusting the valves on the other cylinders. The procedure is listed in the FAQ (I think). So have a look and make sure the cylinder you are working on is at (or very near to) top dead center.
Do this and then let us know if the exhaust valves are too tight. Also, note that it is difficult to access the exhaust valve gap unless you remove the fuel rail cover and use a feeler guage with angled blades.
Ideal compression is about 225 psi with the throttle wide open at 250 RPM. Of greater importance than the value is the evenness across cylinders. There should be no more than 28 psi difference between any two cylinders, though less variance is certainly better.
Old Aug 21, 2005 | 10:51 AM
nvr2fast's Avatar
I was told by my mechanic that the F20C motor has self adjusting values and it doesn't need to be adjusted, or something similar. Is that true, or was he pulling my leg?
Old Aug 21, 2005 | 11:03 AM
SpaZilla's Avatar
i know i can only do one cylinder at a time in order of 1, 3, 4, 2 at tdc for each cylinder
Old Aug 21, 2005 | 12:06 PM
CoralDoc's Avatar
Your mechanic is wrong. The valves in the F20C are not self-adjusting. However, according to the service manual, the valves do not need to be adjusted until 105k miles.
OK, since you were measuring valve clearances correctly, the exhaust valves are seriously out of specification! Were the valves ever adjusted before? A valve that is about to drop tends to have looser than normal gap.
Shordmcman
May 20, 2012 07:23 PM
sharptech
Dec 24, 2007 07:43 AM
ken o
Dec 20, 2005 09:30 AM
Gernby
Oct 25, 2002 11:25 AM
