Valve adjustment tips
Just concentrate on getting slight drag on the proper sized feeler gauge, don't worry about the go-no-go method. If you have slight drag on the proper sized feeler after fully tightened then you got it right.
Best advice I can give noobies is to, go back into the engine 2 weeks after your first adjustment and double check all of your settings. You will get a better idea of how well you did by doing that, and you will have a clearer mind at that time. You always get better the more times you do the adjustments, you will develop the proper feel after doing the job a few times.
RolanTHUNDER
Apr 2, 2018 10:03 PM
