valve spring or retainer HELP!!
Old Mar 8, 2004 | 01:25 PM
Anrosphynx's Avatar
Default valve spring or retainer HELP!!
Hello all! I am new to the board. I just bought a 2001 S2k... Looks awesome. however, I have an issue with it already!
The mom and pop dealership that i bought it from had it checked by honda and said that the valve spring was replaced cause the guy before me revved the car too high. I called the local honda dealer here today and he said it was unusual for the valve springs to go out..
Anyways, I was driving it last night and i revved hard (but not to redline) and it did fine, but as i picked up speed, it felt like the car lost compression.. it was hard to get it to move, even on low revs. and the check engine light came on (blinking).... I immediately parked the car. The one thing I did notice was that the car wasn't fully warmed up yet. 2 bars. Should I normally let the car warm up all the time?? Will this "lack" of compression happen when i don't allow it to warm up?
I started the car today, and it started up fine. no check engine light. Had full compression, like nothing was wrong with it.. What happened? Did I miss something? Did I get a crappy car? only has 50k on it... Any information you guys have would be greatly appreciated. I know very little about these cars or hondas in general. Please help!
Old Mar 8, 2004 | 01:32 PM
aklucsarits's Avatar
When a car gets overreved, it is most often the valve itself that gets damaged and needs to be replaced. On an overrev, the valve floats, and the piston contacts it, normally bending the valve. A bent valve could be causing the loss in power and the CEL you experienced. Although that would not explain why you did not experience the same power issue later...
You should be able to pull the CEL code from the ECU to see what problem the CEL came on for.
Andrew
Old Mar 8, 2004 | 01:39 PM
xviper's Avatar
[QUOTE]Originally posted by Anrosphynx
Old Mar 8, 2004 | 01:53 PM
Anrosphynx's Avatar
so likely what i was feeling was this fuel cut off? Would that also make my CEL go off (blinking.. it didn't stay constently on)?? I really appreciate your help guys.. I couldn't sleep at all last night cause of it!
Old Mar 8, 2004 | 02:00 PM
xviper's Avatar
This, I cannot say for sure. Having the fuel cut may have resulted in a momentary lean condition that was sensed by the ECU, so it may have caused it. I'm not sure.
Old Mar 9, 2004 | 05:10 AM
Squeezer's Avatar
if you rev the engine before 3 bars on the temp guage, it will stop at about 6700 rpm. your CEL light won't blink under this condition though. blinking CEL means something is seriously wrong in your engine, constant CEL means its not serious (emissions). you should get autozone to pull the code for free and then post in this thread or PM me the code and then i'll be able to help. but I wouldn't recommend driving it to autozone or the dealer to get the code, you'll have to buy an OBD-II scanner or get it towed.
Old Mar 9, 2004 | 07:45 AM
hondaS2001's Avatar
Banned
Also, even once you reach 3 bars doesnt mean its safe to start going wild, as the three bars are coolant temp rather than oil temp. Make sure you are driving/warming it up even after you get to 3 bars before you go crazy with the revs. However, this is probably unrelated to your prob as it wouldnt throw a blinking CEL.
Old Mar 9, 2004 | 08:19 AM
Anrosphynx's Avatar
The blinking CEL didn't last though. It just did it while I was driving it. I parked it, and when I restarted it, no CEL, blinking or otherwise. I had it towed to have it looked at. But the fact that it came on worries me altogether.
Old Mar 9, 2004 | 11:31 AM
Squeezer's Avatar
Old Mar 10, 2004 | 08:27 AM
Anrosphynx's Avatar
thanks guys for all your help, I appreciate it. The car is currently at the honda dealership where they are looking it over.. I will let you guys know what went wrong..
9krpms2k
Jul 14, 2012 04:33 AM
UNiT_xEr0
Mar 15, 2012 02:35 PM
JDMQuip
Jun 15, 2011 12:56 PM
dan_uk
Jun 14, 2008 07:49 PM
jrb
Aug 1, 2006 09:07 PM
