venom nitrous/ primary O2 question
Old Nov 28, 2004 | 04:30 PM
NeverSeen's Avatar
Default venom nitrous/ primary O2 question
Hi, my venom kit says to tap into the primary O2 sensor to get a/f readings so the venom computer knows howto adjust the fuel. Venom says its a white wire... my problem... out of the 4 wires, 2 of them are white. The guy on the phone says one is white/black and one is white. this is not the case. i have read that people tap into the ecu harness for the apexi's and such. would this be okay to do with the venom computer, assuming it would be collecting the same info off the sensor as the apexi? i have a 2001.
Thanks for any help!
Tim
Old Dec 5, 2004 | 11:26 AM
NeverSeen's Avatar
bump.
Old Dec 5, 2004 | 11:52 AM
xviper's Avatar
You want the WHT wire that is pin 16 in the ECM connector C (31 pin).
Old Jun 7, 2005 | 02:42 PM
spinmasterext's Avatar
is there anyway you can descirbe the location of that pin in a different way. Assuming i dont have an ECu wiring lay out ( because i don't )
Old Jun 7, 2005 | 04:14 PM
xviper's Avatar
Sorry, you're going to have to go in there and figure out which one is the correct plug by counting the pins. Pin 16 will be in the middle row near the center of the plug. It'll be the only white wire near there.
Old Jun 11, 2005 | 05:36 AM
ItalianBucwheat's Avatar
Yup its bright white. I believe the other white wire that is confusing you is actually a creamy white and not a bright white.
Old Jun 11, 2005 | 07:28 AM
SCvortech's Avatar
this will help you http://plxdevices.com/ECUDatabase/Honda_Ac...N_S2k_00_04.pdf
maticuss2000
Sep 29, 2004 08:31 AM
KenGPW
Aug 20, 2004 11:45 AM
AusS2000
Mar 14, 2004 08:08 AM
johninator
Jan 30, 2004 04:25 PM
