vibration in vtec
Old Apr 30, 2007 | 02:12 PM
Ja3mah's Avatar
Default vibration in vtec
I hit vtec in 3rd gear on the highway and around 7000 rpm there was this rattling noise coming from the front of the engine. i tested again and in 4th gear it is there also.
Old Apr 30, 2007 | 04:19 PM
jyeung528's Avatar
yay for vtec!
Old Apr 30, 2007 | 04:24 PM
Mr. Eryozgatliyan's Avatar
Banned
Sounds like your car is special!
Old Apr 30, 2007 | 04:31 PM
Ja3mah's Avatar
So this means...
Old Apr 30, 2007 | 07:49 PM
R3DS2K's Avatar
3rd gear at 7000 rpm.. whats your MPH.. use that MPH in 5 or 6th gear and if it still does it.. wheel balance..
does the steering wheel shakes
Old May 1, 2007 | 07:37 AM
jelliotlevy's Avatar
That noise you hear in 4th gear at 7000 rpm may sound suspiciously like a State Trooper's siren......
Old May 1, 2007 | 07:48 AM
screaminyellow's Avatar
What grade of fuel are you using? One of the possibilities is that you are pinging from some bad gas! Our cars are setup for 91 octane or better. I have even gotten a bad batch of gas once from a cheap gas station and had a similar problem. ( I pretty much stick to Chevron now!) Also, check your oil level and be sure that it is full, VTEC solonoid likes a full oil pan. If none of the above works then come back and we will try again!
P.S. If it is bad gas, don't go into vtec until you run it all out. You do not want to blow the motor
Old May 1, 2007 | 02:30 PM
Ja3mah's Avatar
hmm i dont think it is the gas because I use 91 all the time, from shell whenever i get a chance. maybe its the oil, should i add oil even after I recently had my oil changed.
Old May 1, 2007 | 08:20 PM
R3DS2K's Avatar
how much oil u put in.. ??
also could u answer my question if not oh well.. just trying to get more info
Old May 1, 2007 | 08:49 PM
Ja3mah's Avatar
4 quarts? im not sure and no r3d my steering wheel does not shake. im sure it is coming from the engine bay.
