Volume down is broken
Old Feb 7, 2012 | 11:18 AM
nartnailuj's Avatar
Default Volume down is broken
When I was driving to work this morning, I noticed that my volume switch was not working. When I pushed it up, it was normal. I could feel pressure or like a click. When I pushed the volume down, it felt loose? Like nothing was underneath it to click. Hopefully I am describing it vividly. It just feels like the button behind it doesn't work anymore. Idk what could have caused that. The only thing I did to my car yesterday was put new parking lights in. And I had to squeeze my hand to put the lights in. Maybe I pulled something and pulled the button that sits behind the down switch out of place?
Can someone suggest what I should do to fix this? Besides taking it to a shop. Thanks
Old Feb 7, 2012 | 12:55 PM
nartnailuj's Avatar
might think this is the solution
https://www.s2ki.com/s2000/topic/582...n-not-working/
anyone know how i can get these pics to work?
Old Feb 7, 2012 | 01:06 PM
nartnailuj's Avatar
i dont see the rubber tabs they are talking about on this picture
https://www.s2ki.com/home/2010/11/10...h-light-bulbs/
Old Feb 7, 2012 | 04:55 PM
nartnailuj's Avatar
Anyone?
Old Feb 8, 2012 | 11:47 AM
nartnailuj's Avatar
No one knows how I could fix this? No one had this problem before?
Old Feb 8, 2012 | 12:35 PM
ahrmike's Avatar
you can order that entire cluster (probably minus the start button) on ebay. You can attempt to take it out/fix it first if you want. Its easy to pop off the gauge cluster surround (you need to drop the steering column first)
Old Feb 8, 2012 | 01:58 PM
nartnailuj's Avatar
so the only way of fixing it, is to buy a new cluster? what is it actually called? the part that surounds the cluster?
Old Feb 8, 2012 | 02:24 PM
dwight's Avatar
I believe you want:
35880-S2A-A12 008 001 SWITCH ASSY., RADIO REMOTE
Old Feb 8, 2012 | 11:15 PM
nartnailuj's Avatar
Oh that's pricey. Ok I'll try to take it apart and see what I can do about it first. I feel safer knowing I can buy that incase I break something. Thanks.
Old Feb 8, 2012 | 11:28 PM
supavinn's Avatar
or maybe the s2k god is telling you its time to upgrade and get a headunit with an aux jack =) it will change your worlddd
