Vortech with E-Manage
Old Feb 7, 2004 | 03:15 PM
Slows2k's Avatar
Default Vortech with E-Manage
Just curious if anyone is running with a E-manage/big injectors on a stock boost Vortech. What are your impressions, How long did it take to tune to get a usable but not perfect Map? TIA
Old Feb 7, 2004 | 07:38 PM
ultimate lurker's Avatar
Having just tuned one, let me say - pull out timing, lots of it, even below boost. I don't know why, but the engine wants to ping on the Emanage with the Vortech. Its almost like the stock ECU's ability to pull timing with the knock sensor is diminished. We got no detonation under boost, but plenty at part throttle??
More investigation needed, as this has not happened on the K-series emanage installations I've tuned, but just a piece of advice.
UL
Old Feb 7, 2004 | 07:48 PM
Slows2k's Avatar
That's interesting, The whole reason I'm investigating the e-manage is due to detonation. I have the software for the Split Second timing controller, And after looking at the supplied Timing Map, It doesn't appear to be taking out much timing. After watching the Data off a PGM-FI tester, the pcm is pulling out timing from the knock sensor at low rpm as well.
Old Feb 10, 2004 | 08:29 PM
Slows2k's Avatar
Shameless bump. Who did UL tune? Care to comment?
Old Feb 10, 2004 | 08:46 PM
You have to remember that even on a stock S2000, the ECU is always pulling out timing. Honda has an interesting way of managing knock sensitivity vs. noise level.
UL
UFfitz56
Feb 13, 2011 12:18 PM
bpaspi
May 29, 2010 11:11 AM
s-cargo
Jun 6, 2009 12:52 PM
A4XRBJ1
May 3, 2005 11:14 AM
johninator
Apr 2, 2004 02:37 PM
