VTEC acting up...
Old Aug 21, 2006 | 06:39 PM
DFWs2k's Avatar
Default VTEC acting up...
I think this belongs Under The Hood...
Anyways, when I start up the car, it runs normal. Driving around town it's fine, but the first time I go into VTEC it doesn't engage as hard as it should, it kinda sputters up and after about 5-10 seconds it engages like it used to and the pull is noticably stronger than it was while sputtering.
The higher cam kicks in around 5600-5800, and the engine gets a lot louder, but more power doesn't kick in for 5-10 seconds, it sounds like it's trying to engage but doesn't.
For about a week it was only when first going into VTEC while driving the car (always let it warm up and stay on 3rd bar for a while), changed the oil, and then it was fine. After about 3-4 weeks, started happening again. Since then it has gotten worse and sputters through VTEC for more than just the first time.
I hope someone has insights as this has me stumped...
Old Aug 21, 2006 | 06:45 PM
Elistan's Avatar
In my experience, disconecting and re-seating the electrical connecter to the MAP sensor (the thingy on top of the throttle body) helped tremendously. Make sure the electrical contacts are clean. Also, double-check your oil level.
Old Aug 21, 2006 | 07:02 PM
DFWs2k's Avatar
Oil level is fine, I'll try the MAP sensor...if the connections aren't clean, any suggestions on what to clean with?
Old Aug 21, 2006 | 08:32 PM
ShocK's Avatar
Rubbing alcohol? just a guess. They have a MAF spray cleaner out now that might be safe to use if its really dirty.
Old Aug 21, 2006 | 11:16 PM
JLEEzAP2's Avatar
Maybe a burnt clutch slipping or it can be your gears.. just a guess..
Old Aug 22, 2006 | 10:07 AM
melonheadr6's Avatar
You can try resetting the ECU also.
It's above the driver's left knee. Pull the 2nd 7.5 amp from the top right corner for about 1min. Then plug it back in. Turn on that car and let it warm up for a few mins. Then give it a whirl. I hope it works.
Old Aug 22, 2006 | 11:14 AM
SpitfireS's Avatar
There is some info here:
https://www.s2ki.com/forums/index.php?showtopic=413018
Read it all the way to xvipers comment about the service bulletin.
It sounds like what you describe.
Let us know what you find.
Old Aug 22, 2006 | 01:17 PM
DFWs2k's Avatar
That sounds like exactly it...definitely will check that out and report tomorrow.
Old Aug 23, 2006 | 10:40 AM
DFWs2k's Avatar
I guess it was the MAP sensor, ziptied it, and it ran perfectly, VTEC feels better than it has felt in a while!
Thanks!
Old Aug 23, 2006 | 10:59 AM
REVZ TO9's Avatar
Banned
check your vtec solenoid. I heard those can rarely go bad.
s2kdriver80
Mar 18, 2010 07:17 PM
qbmurderer13
Aug 10, 2008 01:19 PM
darkfx
Mar 24, 2006 08:32 PM
lower
Apr 29, 2005 09:54 AM
John MI blk/blk '01
May 3, 2002 03:39 AM
