VTEC issue
Thought I had this solved but had an issue this am after a full day running fine at SCCA Starting Line School.
[img alt="This scenario was closest I could fine to mine. Hope I don’t have a problem with rocker arms. Seems odd to me.
Could valve lash cause a poor performing VTEC zone?
"]https://cimg0.ibsrv.net/gimg/www.s2ki.com-vbulletin/920x2000/img_3185_2233be4b3f462e63a59d5a52488d887848db330e. png[/img]
This scenario was closest I could fine to mine. Hope I don’t have a problem with rocker arms. Seems odd to me. Could valve lash cause a poor performing VTEC zone?
engine at wot is struggling to make it to redline.
2001 test pipe, fpik
plugs are 2 years old
oil level good
no leaks
oil level good
no leaks
Does the engine have healthy compression?
could my K&N filter be causing my intake sensor to get dirty?
I could hook up a mechanical gauge to check but I don’t think that’s it.
i’m thinking it air/fuel related.
These cars were designed for dry air filters, not K&N filters dripping with oil. Cleaning the intake and sensors may help as would a dry filter.
This one is a direct replacement for the K&N, can be cleaned and washed, and uses no oil:
-- Chuck
-- Chuck
