VTEC issue
Old Mar 2, 2025 | 05:22 AM
Dibsen's Avatar
Default VTEC issue
Thought I had this solved but had an issue this am after a full day running fine at SCCA Starting Line School.
[img alt="This scenario was closest I could fine to mine. Hope I don’t have a problem with rocker arms. Seems odd to me.
Could valve lash cause a poor performing VTEC zone?
"]https://cimg0.ibsrv.net/gimg/www.s2ki.com-vbulletin/920x2000/img_3185_2233be4b3f462e63a59d5a52488d887848db330e. png[/img]
This scenario was closest I could fine to mine. Hope I don’t have a problem with rocker arms. Seems odd to me. Could valve lash cause a poor performing VTEC zone?
engine at wot is struggling to make it to redline.
2001 test pipe, fpik
plugs are 2 years old
oil level good
no leaks
Old Mar 2, 2025 | 06:32 AM
Chuck S's Avatar
Links don't seem to be links. Those darn brackets...
-- Chuck
Old Mar 2, 2025 | 07:57 AM
B serious's Avatar
Link doesn't work
One thing to check is the screen of the VTEC solenoid gasket. It needs to be clean and not impeding flow.
Old Mar 2, 2025 | 09:40 AM
windhund116's Avatar
Link doesn't work
And is the engine oil pressure staying at spec during full throttle?
Does the engine have healthy compression?
Old Mar 2, 2025 | 11:19 AM
Chuck S's Avatar
Low oil pressure indicator is all the "instrumentation" there is. It's pretty obvious when it flashes on.
-- Chuck
Old Mar 7, 2025 | 01:18 PM
Dibsen's Avatar
Link doesn't work
thanks. VTEC assembly was rebuilt with new gaskets and a new screen last year. I was chasing down an oil leak.
could my K&N filter be causing my intake sensor to get dirty?
Old Mar 7, 2025 | 01:21 PM
Dibsen's Avatar
185 across the board. No drops in pressure that I can tell. No warning or indication.
-- Chuck
right, no flashes.
I could hook up a mechanical gauge to check but I don’t think that’s it.
i’m thinking it air/fuel related.
Old Mar 7, 2025 | 01:22 PM
Dibsen's Avatar
I can rip around most of the time now with no issues. Got the stumble once today.
Old Mar 7, 2025 | 02:19 PM
What did you do to fix the issue?
Thanks!
Old Mar 8, 2025 | 03:41 AM
Chuck S's Avatar
These cars were designed for dry air filters, not K&N filters dripping with oil. Cleaning the intake and sensors may help as would a dry filter.
This one is a direct replacement for the K&N, can be cleaned and washed, and uses no oil:
Amazon Amazon
-- Chuck
