VTEC problems!
Originally Posted by Ztopgun28,Dec 28 2006, 08:45 PM
My gas is fine, no cel and I feel no "kick", but still accelerates, and the acceleration isnt that powerful
1- Uninstalled the Vtec solenoid, cleaned everything inside, also cleaned the Vtec filter (Little mesh)
2 - Ensured that the oil capacity was in full
3 - I did the map whack
4 - Reset Ecu
Problem solved
Also you should check the wiring that goes to the vtec solenoid just in case.
Hope you can solve the problem
Originally Posted by JawKnee,Dec 29 2006, 05:04 PM
However, you won't feel the "kick" right?
you won't feel the same kick if you're applying low throttle but still engaging vtec. Just keep in mind vtech engagement point is determined by several things and just because you hit ~6k, doesn't mean you'll go into vtec. I couldn't tell you how do to this since I'm always pedal to the metal at 6k
