VTEC QUESTION
Old Mar 17, 2009 | 06:25 PM
M2K's Avatar
M2K
Default VTEC QUESTION
I got a question about vtec?
My vtec seem to not have the same kick i use to get.
When there is something wrong with the vtec solenoid will a cel light come on?
Old Mar 17, 2009 | 07:02 PM
istdercollen's Avatar
maybe you are just getting used to it.
Old Mar 17, 2009 | 07:09 PM
Slows2k's Avatar
If the cel is off it's fine.
Old Mar 17, 2009 | 07:17 PM
ChefJ's Avatar
Check your air filter. And as Slows stated if you don't have a p1259 or similar code you are gtg
Old Mar 18, 2009 | 10:46 AM
Nickamsweet's Avatar
clutch slipping? my power is terrible atm due to it... not going into vtec at all...
Old Mar 18, 2009 | 02:01 PM
neveronlines2k's Avatar
Check oil, if its low it could effect VTEC.
When VTEC engages in the S it is more subtle then other H motors though (if you are used to a different motor and just got the S).
Usually when you feel VTEC the most is when the VTEC dip or drop in HP right at the engagement point is somewhat drastic, after tuning the transition is much smoother and most S's I have driven were pretty smooth (at least compared to most B/H/K series motors).
Old Mar 18, 2009 | 04:46 PM
E_N's Avatar
E_N
Have you been generally keeping up on maintenance? You could also try the "ECU reset" by unplugging the battery. Sometimes that will help if your car learned a bad habit.
Old Mar 19, 2009 | 08:20 AM
hirev's Avatar
the ecu reset and a new battery made a difference in my car and i have a 2004. sometimes it seems an oil change make for a better power delivery as well.
MANOS_BLUE
Κινητήρας - Μετάδοση - Περιφερειακά
Apr 14, 2009 10:33 AM
