vtec stuttering
Old May 25, 2008 | 07:10 AM
mikeyb's Avatar
Default vtec stuttering
Hi guys,
Anyone have a problem with your car stuttering while in vtech? Last night i was going home and opened my car up a little and in vtech it would pull strong then let off and then pull strong again and then die down again. It seemed like it wasnt pulling vtech at all around 7k and then my check engine light started flashing and then I let off the gas and the check engine light went away. Any suggestions? My car is bone stock.
Thanks,
Mike
Old May 25, 2008 | 10:45 AM
negcamber's Avatar
Check your oil level.
BTW...if you haven't had your car long, bit of advice...check your oil twice as frequently as any car you've ever owned before. The early s2ks use oil faster than many other cars. Special banjo bolts squirt oil on the cyl walls to keep them cool while the pistons pass by at 9000rpm.
Old May 25, 2008 | 10:47 AM
00S2Ked's Avatar
yes b CHECK that oil son!!
Old May 25, 2008 | 11:06 AM
qbmurderer13's Avatar
Try leaving the phone in the charger overnight.
vtech = phone
Vtec is what you have.
Old May 25, 2008 | 11:22 AM
ChefJ's Avatar
my vtech studders a little when going from analog to digital. Have you checked your service plan???
Old May 25, 2008 | 11:28 AM
mikeyb's Avatar
vtech = phone
LOL. My bad Vtec. Will check my oil level after work. I also read something that it could be the MAP sensor wearing and changing the resistance or something. But I will check the oil first since it is less of a hassle. Thanks for the replies.
Mike
Old May 25, 2008 | 01:41 PM
negcamber's Avatar
MAP doesn't impact vtec.
Old May 26, 2008 | 07:10 AM
mikeyb's Avatar
Good to know.
https://www.s2ki.com/shared/library/TSB/a04-073.pdf
Hesitation during high rpms. Guessing while in vtec? Not sure.
But I did check the oil level and it was low. Tested it out and everything went smoothly again.
Mike
Old May 26, 2008 | 07:26 AM
negcamber's Avatar
[QUOTE=mikeyb,May 26 2008, 10:10 AM] Hesitation during high rpms.
Old May 27, 2008 | 07:37 AM
mikeyb's Avatar
7 years is a long time and you were absoultely right about the low oil. Thanks again
