VTEC wont engage in first gear!
UPDATE - Just took the car out. Let the car sit and warm up to 3 bars. Tried VTEC in first gear, no go. Engine just revs..No sound from VTEC and no boost at all. Dropped to second and hit 6K, VTEC screamed as usual and car took off.
Was able to try once more before i pulled into work. VTEC in first kicked in VEERY sluggish, nowhere near normal or the same behavior in 2nd or third gear.
Should i try an ECU reset? I don’t know how to do it but i assume i can pull the battery cable tonight and let it sit until morning?
Thanks guys!!
Thanks guys!!
The oil level is OK. I assume if the oil pressure is bad i need to replace the oil pump? I revved the engine cold and i know i shouldn’t have but what’s done is done. That’s what caused this to happen so that’s why i was thinking an ECU reset might do the trick before i started on other things. I also read the link posted above about cleaning the VTEC solenoid filter thing but i would need a DIY guide on it. I’m not a mechanic so I’m kind of scared to do it on my own but i will if it’s something simple.
Thing is, when i hit VTEC on the cold motor it did kick in the all of a sudden bogged down and the car seemed sluggish. I depressed the clutch and went to second and the car drove normally. After that i tried VTEC from first again and had no response.
You might be experiencing placebo effect...
In order for VTEC to engage, you need:
Proper operating temp
proper oil pressure
proper throttle position
proper RPM
In addition to the stuff above, certain CELs will cause VTEC to not work, or problems w/ your tachometer, leaky VTEC solenoid gaskets, etc.
proper oil pressure
proper RPM
Is there a DIY VTEC solenoid guide i can use to look the VTEC over?? Im not a mechanic but i know where the solenoid is and i am sure i can do and inspection if someone can help guide me through it.
ummm... no it wasnt and i know thats a boo boo....
