warm idle?
S2000 Technical and Mechanical discussions.
warm idle?
Dec 1, 2008 | 11:05 PM
combats2000
Nov 2008
Ventura, CA
warm idle?
@ what rpm does the s2k idle warm?
i was adjusting the throttle cable and didnt take notes where it idle'd b4.
its steady at around 800-900 looks like
thanks
combats2000
Find More Posts by combats2000
Dec 2, 2008 | 12:37 AM
CarbonYellowJ's
Nov 2007
the idle air control valve should compensate for small adjustments. I would not adjust your throttle cable besides to remove excess slack.
CarbonYellowJ's
Find More Posts by CarbonYellowJ's
Dec 2, 2008 | 08:15 AM
armthehomeless
Nov 2007
Columbia Mo
With no load ( all accesories off , especially AC ) it should be at 800 +/- 50
armthehomeless
Find More Posts by armthehomeless
Dec 2, 2008 | 09:16 AM
combats2000
Nov 2008
Ventura, CA
i had major slack, its at 800. thanks for the quick response.
combats2000
Dec 6, 2008 | 03:59 PM
funkemonke
Apr 2008
texas, ft. hood
mines around 900-1000, somestimes falls a little under 900. just adjusted valves (.008-.010) perfect!
funkemonke
Find More Posts by funkemonke
Possible bad idle air control valve?
cbs_24
03:36 PM
P0507 High idle
Heiachi
06:49 AM
Coolant bypass of IAC valve and throttle body.
LUVNMBRS
04:41 PM
Throttlebody help...adjusting?
jallen_69
09:32 AM
Back to Subforum
View Next Unread
New flywheel necesary when doing a clutch change?
01:55 AM
