Wastgate on supercharger??
Old Jan 3, 2003 | 03:55 PM
jlangton's Avatar
Default Wastgate on supercharger??
I know that this has been talked about numerous times, but has anyone done this yet???
I would really like to know your results and how exactly you did it (not really sure how these things work), cause i would like to get a 12 or 13 psi pulley and not have anymore than 8psi come through....until i upgrade internals and fuel anyway, so that I can produce more boost down low and be more consistant across the board.
Old Jan 3, 2003 | 08:59 PM
davidb's Avatar
I have not done it, but I have seen it done. The dyno results were impressive although many people (who had turbos) swore the parasitic losses would negate any advantage, but like I said the dyno looked great!
This was on a Miata so there are no comparisons.
The guy has since upgraded to a high boost turbo system because he wanted MORE POWER!
Old Jan 3, 2003 | 09:10 PM
jlangton's Avatar
Is there anything special that I would need to know?
Or do I just need a wastegate, a smaller pulley and a competant mechanic/tuner?
Old Jan 4, 2003 | 09:13 AM
s2kpdx01's Avatar
You saw this done? Where who?
The parasitic losses are not going to be much worse (if any) then running standard 8 psi pulley. Once you are blowing the excess boost off, the load falls off quickly. Of course you will be boosting 8 psi for a larger chunk of revs, but the extra power will more then make up for the extra parasitic loss.
A turbo will still have less parasitic loss, but this would make a simple SC system a whole lot more effective for very little extra money.
Old Jan 4, 2003 | 09:16 AM
s2kpdx01's Avatar
[QUOTE]Originally posted by jlangton
[B]Is there anything special that I would need to know?
Old Jan 4, 2003 | 03:18 PM
davidb's Avatar
As I said the guy has since gone to a high boost Turbo system 15+ psi.
The dyno proved the lie to parasitic losses getting the better of him.
Old Jan 5, 2003 | 11:54 AM
jlangton's Avatar
I'm trying to do a little research on it, but at least in theory it should work.
I am probably going to try it, but it will be a little while....gotta save some money for a smaller pulley and the wastegate.
It seems as though it would be well worth it, should produce some nice power across the board.
hvAlfaWant_S2000
Mar 30, 2015 10:07 AM
CourageOO7
May 26, 2010 05:38 AM
visser
Jul 25, 2007 12:54 PM
Initial D God Hand WannaBEE
Feb 21, 2007 06:06 AM
