Water in the trunk!
Old Dec 13, 2011 | 07:08 PM
poweredsince85's Avatar
Default Water in the trunk!
I've noticed recently that everything in my trunk has been wet and there has been water at the bottom. So a few days ago, I decided to rip out all the lining and found water sitting at the bottom of my trunk. It seems like it would get better or worse, but has been there for a little while. I figured it was because I moved to South Florida and it rains a lot here, it was just leaking from somewhere around the trunk. However, it is not wet anywhere on the top, it seems like it is coming just from the bottom. Anyone have a problem like this or seen anything like it?
Old Dec 13, 2011 | 07:45 PM
OVER 9000!'s Avatar
I have the same problem, but there wasn't as much water in my trunk as yours. I'm still searching for the cause, but I'll bet it's a small leak around the edge of the soft top. Good luck.
Old Dec 13, 2011 | 07:52 PM
trAP2's Avatar
same problem here
Old Dec 13, 2011 | 07:56 PM
BBV S2K's Avatar
same here... not that much of water but it happens too...
I just removed one of the rubbers on the trunk so the water can run....
Old Dec 13, 2011 | 08:28 PM
poorb0yw's Avatar
Check the drain tubes for the soft top to make sure they haven't clogged. They exit in front of each rear wheel.
Another place to look is the air vent for the trunk area. You can access it by pulling the rear bumper. The inside will be visible on the left side of the tool recess now that you have removed the trunk lining. It is a black rectangular plastic piece with a flap to let air out. Check to see if the gasket has dried up on the outside. If so, you can reseal the edges of the vent with silicone.
Old Dec 13, 2011 | 09:01 PM
99SH's Avatar
I have the same problem, and I have a hardtop. The entire trunk fills up with water up to where the tool cover sits. I've drilled out both drain holes to avoid puddles.
Old Dec 13, 2011 | 09:48 PM
Kenshyn's Avatar
I recently had a JL Audio stealth box installed and when we took the trunk liner out there was a very small amount of water surrounding each plug, or drain hole. No idea how water got there considering nothing else in my trunk was wet or gets wet.
I'm not worried about it though considering it was such a small amount of water.
Old Dec 14, 2011 | 01:20 AM
ahrmike's Avatar
water comes in from around the btotom of the trunk seal. Get RTV sealant and fill around the trunk seal. It'll happen often if you park with the car pointing downwards.
Old Dec 14, 2011 | 05:09 AM
zeroptzero's Avatar
there are about 4 known causes of leakage, a few threads exist on each. Some have found water coming in around the antennna, some through clogged softop drain holes, some through the air vent behind the bumper (I caulked mine as a precaustion when I had my bumper off), and some from the seal area.
Old Dec 14, 2011 | 05:12 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
old problem.
here's the fix:
https://www.s2ki.com/s2000/topic/465...trunk-picsfix/
