weird brake problem
Old Oct 2, 2008 | 08:56 AM
Tjs S2k's Avatar
Unhappy weird brake problem
I changed my brakes on my s2k a long time ago. Just got drilled/slotted OEM rotors. Cant remember what pads. Well they worked great for about 2k miles. Now if im on the highway and barely press down I can hear a grinding on the right front. But if I push down a little more they go away. If I am sitting at a light , I will pump my brakes and then if I barely push down right after that (when I get moving) it doesnt grind. I have bled my brakes 2 times and it still does it. Also when I first push down the brakes when Im about to pump them the petal goes down about an inch then I hear a click in the petal then it goes away. I was thinking something is wrong with the caliper. Any ideas?
Old Oct 2, 2008 | 10:52 AM
billiardboy904's Avatar
possibility that your rotors are making noise as they scrape off the pads. Did you get your OEM rotors drilled and slotted or did u buy some oem drilled/slotted?
Quick question. what made you go with changing your rotors to drilled/slotted?
Old Oct 2, 2008 | 11:27 AM
Tjs S2k's Avatar
looked 10x better, and I heard they were better at cooling (warped oem) i bought them from a company, Just OEM size is what I meant. I dont think that caliper is closing all the way down on the RF tire.
unbreak_s2k07
Oct 17, 2010 09:43 PM
Presto123
Aug 3, 2010 01:48 PM
P-CarDriver
Feb 17, 2010 12:23 AM
Tjs S2k
Jul 18, 2008 10:28 AM
rrk0818
Jun 28, 2008 07:07 PM
