Weird braking issue?
Old Sep 22, 2010 | 09:05 PM
tukin17's Avatar
Default Weird braking issue?
When i slam on my brakes ive been noticing kinda like a vibration coming from the passenger side front any suggestions what it could be??
Old Sep 23, 2010 | 04:14 AM
PJCC's Avatar
Sounds like a warped rotor.
More information about the condition of the brakes and your braking/driving habits will help you get better answers.
Old Sep 23, 2010 | 04:47 AM
w00t692's Avatar
Do you feel it in the pedal too?
Old Sep 23, 2010 | 07:42 AM
my2ks2k's Avatar
Originally Posted by hecash,Sep 23 2010, 09:03 AM
I just helped a new friend change the rotors on his car because it had a shudder after a track weekend.
Here's a primer from StopTech on the myth of rotor warping.
StopTech Rotor Warp Myth
that's a good read for several reasons
Old Sep 23, 2010 | 10:18 AM
w00t692's Avatar
Well technically, although pad material deposited on the rotor. Think about it and you can see why someone would feel that they are warped.
Higher points + lower points = feels warped.
Old Sep 24, 2010 | 12:32 PM
idea-catalyst's Avatar
Yes it might behave as one would imagine a warped rotor would behave, but if it were truly warped instead of suffering from some 0.001" magnitude deposits, the cure would be A LOT different. How many shops turn rotors down by 0.010 or more? If these tiny cementite spots are not visible to the naked eye, how much you turn a rotor is simply a matter of chance.
Interesting that no one alleging "warped rotors" ever put a dial indicator on the rotor and discovered that it was, in fact, not warped.
That's a great article on brakes!!!
Old Sep 24, 2010 | 01:05 PM
xredjar's Avatar
The only thing I want to point out from the StopTech article is that he mentions the rotors being tightened uniformly, and to the proper torque spec.
I know for a fact that no shop I have ever encountered hand torques wheels when they are put back on. Much less to the proper torque spec. They grab the old impact wrench, and zing them on as tight as they can get em. When I've requested they be hand torqued....I get the argument that they have the devices that stops the gun when it gets to the proper torque, but IF they are really using them....they don't work.
I've had words with several techs and shop managers when I while still in the parking lot....pull out the breaker bar and torque wrench and show them how uneven and over torqued they are.
Uneven, and over torque on the lugs will cause a rotor to warp.
While I don't discount that there are a lot of cases of what feels like rotor warp due to uneven material being transfered to the rotor, in the general consumer realm I'm sure just as many if not more are due to the rotors being over torqued, or not torqued uniformly.
Just my $.02
Moddiction
May 20, 2014 01:39 PM
Moddiction
Sep 15, 2013 06:51 AM
thbirdman
Aug 26, 2013 02:50 PM
ChrisD
Jan 27, 2002 11:43 AM
