Weird clicking
Old Jul 22, 2008 | 05:31 AM
cougar hunter's Avatar
Default Weird clicking
I just started hearing this little "click" noise whenever i go from a stop. It also did it this morning when i started moving in reverse. if anyone could tell me what to check, that would be great
tia
Old Jul 22, 2008 | 05:36 AM
my2ks2k's Avatar
re-torque your axle nuts to 220 lb/ft.
my2ks2k's Avatar
oh and stop hunting cougars. they're becoming endangered
Old Jul 22, 2008 | 06:28 AM
are we talking about the same cougar?
Old Jul 22, 2008 | 06:29 AM
Pruhnke's Avatar
I have that noise also It started shortly after I installed my KW V3 coilovers so I thought it was something with the helper springs. Mostly comes from the driver side rear. Never noticed it going in revserse though.
Does anyone know the TSB that covers this?
TSB 011201 Rear Axle - Single pop or creak from rear of vehicle
Found it
Old Jul 22, 2008 | 06:50 AM
TubeDriver's Avatar
Single click or pop - retorque axle nut to 220 lb/ft
multiple clicks when starting from a stop in first gear or reverse - the axle splines are dry and need to be relubed.
Old Jul 22, 2008 | 08:14 AM
mine is just a single, the car has 25k, dont know if that matters or not
Old Jul 22, 2008 | 10:09 AM
AeroS2000's Avatar
hey guys. i get a click on my driver side rear tire too.
what is the axle nut and where is it located? thanks
Old Jul 22, 2008 | 10:21 AM
esmith51's Avatar
Need to relpace the nuts too. I ordered some form Hardtopguy.
Old Jul 22, 2008 | 10:48 AM
my2ks2k's Avatar
if you take the rear wheel center cap off, you'll see the axle nut. it's 36mm
