Weird Clutch Problem
Old Sep 24, 2010 | 06:25 PM
19wrath85's Avatar
Default Weird Clutch Problem
Well I found this very interesting and quite weird and cant figure out what the hell is wrong, basically when a driver applies the clutch and put the car in gear and releases the clutch without giving any gas the car usually stalls and dies right? Well when i do that my car continues running...weird right? sounds like the clutch is stuck disengaged which basically means that if its stuck i should be able to start the car without applying the clutch right? well i cant...
If you have any ideas of what is wrong or know what is wrong please let me know
Old Sep 24, 2010 | 06:28 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You cant start it without the clutch, it has a switch that prevents that.
My best guess...you have a mis-adjusted clutch master cylinder rod under the dash, and the system is holding pressure.
Old Sep 25, 2010 | 06:43 PM
19wrath85's Avatar
well how do i adjust that?
tehsu
Jan 4, 2011 12:42 AM
purekoryo
Oct 30, 2010 04:37 AM
uclanentsu
Mar 15, 2008 11:18 AM
cmn
Jan 18, 2007 01:08 PM
Pinky
Mar 17, 2002 10:27 AM
