weird noice that sounds like its from the diff?
Old Oct 4, 2003 | 01:00 PM
BlueS2000Boy's Avatar
Default weird noice that sounds like its from the diff?
ok when ever i am slowing down i hear a loud whinning noise when i am in nuetral, i don't think its the clutch tsb like everyone else talks about because when i get even slower its turns into a knocking or clicking noise until i come to a stop. its sounds like its coming from the rear end. probably my diff. any ideas what it is? i have almost 25k miles i'm just hoping i just need to change my fluid.
Old Oct 4, 2003 | 01:20 PM
Dubai's Avatar
Yeah,, tell me ..
It is not the Diff.. i think u mean the rear C.V Joint
I have changed my rear CV joint.... and I think again it is clicking--- Time to replace it..........
Old Oct 6, 2003 | 02:37 PM
anyone else?? help
Old Oct 6, 2003 | 05:45 PM
ItalianBucwheat's Avatar
Clicking is cv joints. Whining could be a bearing in the rear diff.
Get under the car and feel where the rear wheel axles connect
to the diff see if there is any fluid floating around, it should be dry if there is some fluid most likely one of your oil seals is shot and the bearing might be on its way out.
Old Oct 6, 2003 | 05:57 PM
ultimate lurker's Avatar
O.k. then folks, answer me this - what is a creaking noise from? I have a very unusual noise from the right rear. Only happens after driving for a few miles (car is warmed up then). Not a single noise, but rather a series of small creaks each wheel revolution (and only during a small part of the revolution). Noise has been getting worse. Can be eliminated temporarily by backing up, stopping, and then going forward again.
Only thing I can think of is axle, wheel bearing or brakes. The rear rotors are shot, and I'm going to tear them down ASAP, but I haven't been able to see anything yet.
UL
Old Oct 6, 2003 | 06:03 PM
krazik's Avatar
Administrator
sounds like wheel bearing to me UL. Could be brake pads too.
Old Oct 6, 2003 | 06:54 PM
integrate's Avatar
[QUOTE]Originally posted by ultimate lurker
Old Oct 6, 2003 | 08:08 PM
sylvir2k's Avatar
wheel bearing noise is typically a low groaning type noise, it gets louder as speed increases. I'm not sure if you would hear it going in reverse since your not upto speed for the noise to be noticeable.
Clicking is usually associated with the axle or cv-joint. I had a clicking in my right rear aswell. I believe there is a TSB for this. I believe they remove the axle nut repack bearing with grease and retorque the axle nut.
Old Oct 6, 2003 | 08:36 PM
You can hear this noise best at low speeds. In fact, just creeping forward at under a mph is the best way to discern it. I'm hoping its brakes.
UL
Old Oct 7, 2003 | 08:05 AM
