Weird noises! help!
Old Oct 9, 2006 | 12:45 AM
VaragS's Avatar
Default Weird noises! help!
So recently....my car has been making a noticeable ticking sound upon acceleration at the beginning of each gear at the lower rpms.. figured maybe it was that "timing chain"(or something like that) issue that i read so much about on this site. I figured no big deal, then like a month ago the S started to make somewat of a grinding sound on start up and would go away immediately at ideal. Now i knew i was heading into a problem....then just 2 days ago a new squealing sound started, almost sounded like break pads but it does it at ideal as well so that cant be it....as the car gets warmer and i drive it more the "whining/squealing/crickets chirping" sound gets more constant and prevalent. And the 2 previous sounds i mentioned before still occur as well.
My s2k has 103k miles on it....however the engine was replaced at 77k with a brand new engine...so why am i getting weird noises??
anyone got any ideas??
Old Oct 9, 2006 | 01:06 AM
RACER's Avatar
Old Oct 9, 2006 | 04:29 AM
Kenpo_S2000's Avatar
Originally Posted by RACER,Oct 9 2006, 01:06 AM
You love this picture don't you.
Old Oct 9, 2006 | 05:36 AM
snakeeater's Avatar
Sounds like you have a bearing going bad. But you haven't stated that you've had any drivability problems. So I would guess it's probably on one of the accessories driven off the serpentine belt. Get it looked at soon. Cheaper to fix it now.
Old Oct 11, 2006 | 12:59 AM
VaragS's Avatar
no the car drives just great....its just the sounds that scare me from driving it the way i normally do. Does anyone else think its the serpentine belts as well? is that expensive to replace?
Old Oct 11, 2006 | 02:25 PM
snakeeater's Avatar
I didn't mean the belt, but the bearings on one of the shafts turned by the belt. This includes idler pulley, alternator, A/C compressor, water pump, etc.
Old Oct 23, 2006 | 12:54 AM
VaragS's Avatar
I just changed my Timing chain tensioner thinking that it may have solved the weird noise squealing/chirping noise. But it didnt so im debating returning it...does anyone have any other ideas?
Old Oct 23, 2006 | 01:03 AM
RACER's Avatar
I dun't think you can return the tensioner after it's been installed
Old Oct 23, 2006 | 01:04 AM
RACER's Avatar
Did you do this yourself?
Old Oct 23, 2006 | 01:02 PM
VaragS's Avatar
yup i did it myself....im not sure if honda will return it but i dont hear any differences with the new TCT...neither with the ticking nor squealing/chirping
