What is this?
Old Jun 12, 2010 | 07:34 AM
Spec_Ops2087's Avatar
Default What is this?
I was looking over my engine today, in prep for some hard driving tomorrow, and I noticed something.
There are 2 hard vacuum lines that run under the fuel rail. The top line goes to what I think is a small in-line filter and then to the left of a black box behind the crossmember. The bottom line goes to a sensor which then goes to the right side of this black box. I just noticed the bottom line (to the sensor) is not connected.
What is this sensor / box behind the crossmember and is there a problem with the one line disconnected?
Thanks
Old Jun 12, 2010 | 07:47 AM
NM, figured out what it was,
Sensor is the Air control valve, black box is air control vacuum res. Seems to be part of the air pump system during cold start. Since I have an AEM EMS, I guess I don't need these parts anymore? (I removed my EGR valve)
Old Jun 12, 2010 | 03:40 PM
s2klariat's Avatar
Exactly if you wanted to you could actually remove all that plumbing and the air pump behind the bumper. Hold onto it all though if you do incase you go back to stock
Old Jun 12, 2010 | 08:33 PM
s2k aok's Avatar
i got extra long vacuum tubing and tucked that crap away...
Old Jun 13, 2010 | 02:45 PM
Cool, out it goes! Thanks
Old Jun 13, 2010 | 11:32 PM
H22toF20's Avatar
You'll throw a cel if you remove it without some sort of EMS.
masters02
Apr 30, 2013 04:40 AM
Serg2K
Aug 3, 2011 11:40 AM
tobbe__86
May 1, 2011 05:37 AM
lotus7racer
Sep 22, 2008 10:31 AM
simonprelude
Aug 13, 2006 02:09 PM
