What Am I Doing Wrong!!
Old Aug 16, 2003 | 10:38 AM
sickestS2k00's Avatar
Default What Am I Doing Wrong!!
hey everybody. recently i went to the track with just an injen cold air intake and ran consistent 14.411. then about 2 weeks ago i added the 6lb titanium jic single exhaust and the toda racing header. i mean, i did feel a difference with them two installed. on the freeway, the car pulled harder and it just had a different feel. then yesterday i figured let me see if i can do any better at the track. the temp was like 80 degrees and it was pretty humid here in jersey. but that wasnt the case. i couldnt pull a better time than 14.411. instead the whole night my best time was 14.444. i mean, even if it was jus shavin off hundreths of a second, how come the header and exhaust didnt help last night? do i need to disconnect the batter or the fuse box for them to adapt to the settings? thanks
Old Aug 16, 2003 | 01:08 PM
fltsfshr's Avatar
I don't know how much more you expected from your exhaust. if you're lucky you are gaining about 5 or 6 hp no more. dual catbacks get about 4 to 5 more that's it. The header etc and exhaust that hondas come with is a very good flowing exhaust system to begin with...so your gain is just a little in hp and a little less weight
but every little bit helps
fltsfshr
Old Aug 16, 2003 | 01:51 PM
Reignman's Avatar
Yeah adding a header and exhaust wont add much power and so at the track it wont translate into much better times. I also find that this car is hard to launch and get consistant times at the track so I find it hard to compare before and after mods.
Old Aug 16, 2003 | 07:16 PM
pjkwong's Avatar
Could it be tire pressure or the amount of gas u had in the car?
Old Aug 16, 2003 | 09:27 PM
fly_S2K's Avatar
A dyno run would prove gains rather than track times. As Reignman stated, launching on this car is really inconsistant. Just my pennies.
-Johnny
Old Aug 17, 2003 | 02:36 AM
NNY S2k's Avatar
You lost me with that statement, so I'll say maybe the weather conditions were differant from your previous runs. Try again on a cooler/less humid nite, I bet you'll do better.
Old Aug 17, 2003 | 06:13 AM
actually i didnt lower the tire pressure and i had like 2 bars on the car when i hit the track. yeah i know, launching on this car is hard. everytime i launched, i would sit there spinning the tires, no traction at all. i will go back on a much cooler night and see if i do better. cuz it was hot as hell when i went the other night and so humid outside! i was sweatin my ass off. but now the question, how do i reset the ECU?? thanks
Old Aug 17, 2003 | 08:26 AM
spider's Avatar
Instead of comparing 1/4 mile time, try looking at the trap speed. There are just way too many variables from day to day at a drag strip. 0.03 seconds is insignificant. Now, if you consistantly finished with higher trap speed (2 - 3 MPH), that means the car gained more HP.
Old Aug 17, 2003 | 11:18 AM
ok i got the whole track thing, but still, how do i reset the ECU!!!!!!!!
Old Aug 17, 2003 | 11:55 AM
Reignman's Avatar
Look at the fuses under your dash on the drivers side. On the left side one fuse down from the top there should be a 7.5. Pull that out for 10 seconds and then put it back in the same way you took it out.
