What do exhaust leaks cause?
Old May 20, 2008 | 04:32 PM
Moddiction's Avatar
Former Sponsor
Thumbs up What do exhaust leaks cause?
Just curious what effects an exhaust leak has on performance. The place that bolted up my exhaust for me, didn't have gaskets and just used gasket maker. It looks like they just used it all around the outside of the flange. So I would think there must be an exhaust leak somewhere. If there is does that have any negative effects on performance or anything really? Hard to tell from listening since my exhaust is really loud, but one of the exhaust tips seems to have more air and sound coming from it. Does that sound like one of the connections is leaking along the line somewhere?
Old May 20, 2008 | 04:55 PM
JmanS2k's Avatar
it's hard to say by not being able to hear it, but if you do have a leak then you're probably losing backpressure.
Old May 21, 2008 | 08:27 AM
iDomN8U's Avatar
You should be able to feel it with your hand or a lighter. Narrow down the leak
Old May 21, 2008 | 08:39 AM
Moddiction's Avatar
Former Sponsor
How do you feel it with a lighter?
I am mostly wondering what the negative effects of an exhaust leak are. Will it rob power? Make the car run worse? What?
Old May 21, 2008 | 09:03 AM
iDomN8U's Avatar
take a lighter to where you suspect the exhaust leak and see if the flame is disturbed.
Granted the conditions in room need to be still.
The effects are a drop in pressure and therefore a decrease in savaging.
net result, loss of power
Old May 21, 2008 | 09:16 AM
Moddiction's Avatar
Former Sponsor
Do you know how significant the loss in power can be? Like can it max be like 2 hp or are we talking possibly much higher hp loss possibility?
Old May 21, 2008 | 09:27 AM
jshimer23's Avatar
I can't imagine anyone giving you an exact # as far as how much HP could be lost. It'd be hard to even give you a rough estimate. If you would loose any meassurable amount of HP from an exhaust leak, I would think it would have to be a pretty major leak. In that case, you should be able to hear it clearly.
As some one said, check the points where a gasket should be. Use a lighter or you could also spray some soapy water on the flanges to see if you get some bubbles.
Personally, gaskets aren't really all that expensive. I'd say get some and slap them on to give you the peace of mind.
Old May 21, 2008 | 10:24 AM
Moddiction's Avatar
Former Sponsor
Yeah I will be getting some gaskets, but have been having a tough time finding the ones that mate up between the stock cat or test pipe and then aftermarket cat back. I contacted Spugen since i have their exhaust and they never reply. Don't even know if they are still making any exhausts anymore.
Old May 21, 2008 | 10:46 AM
negcamber's Avatar
Here is a dyno showing the impact of exhaust leaks.
The black line is the car in healthy condition.
The red line is the same car that had been VAFC tuned (which should give more hp) but ended up having an exhaust that was falling apart from bad welds. Note: this is on the same dyno with nearly identical weather conditions.
iDomN8U's Avatar
I'm shocked if a exhaust shop wouldn't have it
