What fluids to change?
Clutch fluid:
To start, empty the mater with a turkey baster.
Using small pieces of paper towel, clean out the master till its spotless. (no amount of flushing will remove the black sludge you will find)
Fill it back up with brake fluid.
IF YOU LIKE, you can bleed a little off while the car is on jackstands for the other fluids. Just dont let it run low and suck air its a bitch to bleed.
