What is normal compression (cold and hot)
Old Oct 23, 2014 | 03:14 AM
Ed'sS2000's Avatar
Default What is normal compression (cold and hot)
With the engine at room temp of about 80F, I get 185-195 compression (wide open throttle) and it takes about 4 cycles to get there. All cylinders the same. Car has 170k miles. Didn't measure engine warm. Sound healthy enough?
Car consumes oil. I guess about a quart every 300 miles. I don't see any smoke or leaks. No smoke on morning start ups. It just drops on the dipstick. Plugs look normal too. Any ideas? PCV? What else can I check?
Old Oct 23, 2014 | 03:30 AM
Chance S2K's Avatar
Sounds like the engine is more than likely healthy, the main thing your looking for is consistency across the numbers.
I think "good numbers" for a fully-warm engine is 220 across the board. I know that high mileage F20 engines are very prone to burning oil, but I don't exactly know what causes it. What oil are you using? I know that Mobil 1 has (what seems) to be a much higher tendency to burn than other brands.
Old Oct 23, 2014 | 06:53 AM
jkelley's Avatar
A quart every 300 miles is NOT healthy.Comp numbers seem fine from what you've asid alone, but I'd get a leak down asap.
Edit: and yes, check your PCV. With the engine running squeeze the lead hose and have your ear near the PCV. If it make a 'click' sound when closing and opening flow on the lead tube then it's fine. If not, it's not fine.
Old Oct 23, 2014 | 07:25 AM
Chance S2K's Avatar
Oh shit yeah, I didn't see that he listed it was losing such a substantial volume.
tugsta
Oct 5, 2008 02:54 AM
Bassoctopus
Apr 20, 2005 10:38 PM
RossoS2K
Feb 28, 2001 10:26 PM
DJHohum
Feb 20, 2001 11:32 AM
