What is the purpose of this hose?
Old Jan 11, 2015 | 03:13 AM
merkis1024's Avatar
Default What is the purpose of this hose?
i need to replace my intake tube because it cracked. I was wondering what is the purpose of the hose that is connected on the radiator side of this tube?
circled red in pic attached
thanks in advance!
Old Jan 11, 2015 | 04:38 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It provides filtered air to the air pump under the drivers side headlight.
Old Jan 11, 2015 | 08:27 AM
merkis1024's Avatar
Ohhhh billman thank you!!
Another user here gave me his ap1 intake tube (mines an 04) and it looked like this hole on his tube was completely plugged from factory. Any idea why ap1's would be like this?
Old Jan 11, 2015 | 08:34 AM
gptoyz's Avatar
He deleted the air pump which renders that tube useless
The air pump simply warms up your cat faster
Old Jan 11, 2015 | 08:47 AM
zeroptzero's Avatar
ap1 intakes did not have the hole plugged from the factory, the owner must have done that when removing the air pump system. You should be able to open it up but you will need the metal connector plug for inside of the hole which you can transfer from your old pipe.
Old Jan 11, 2015 | 09:05 AM
merkis1024's Avatar
wow interesting.
great to have knowledgeable guys like you guys
thanks again!!!
ps- i hope you guys like my delicate work to close the crack on my tube hahah
Old Jan 11, 2015 | 03:08 PM
zeroptzero's Avatar
^ they often crack after a certain age, mine did and I bought a new one.
chubbys2k
Apr 26, 2016 11:24 AM
Beyond_Redline
Jul 15, 2012 11:22 AM
touch
Apr 11, 2010 10:15 AM
Kev!n
Jul 19, 2009 04:24 PM
