What is this sound
Old Sep 7, 2013 | 06:18 PM
Danwolski's Avatar
Default What is this sound
So there's a clicking sound coming from my front right wheel. The sound itself sounds like the noise a torque wrench makes and it seems to happen every rotation of the wheel, regardless on whether im turning or not. Its reaally quiet though, I have to throw the car into neutral(aftermarket exhaust) and I hear it bouncing back off of other cars that are parked on the other side of the road.
I have jacked the car up and tried moving the wheel at 6-9 and 12-6 and nothing happens, I jacked the car up and rotated the wheel while it was in the air and the sound was not re-created. I tried to check if anything was rubbing with the car on the ground but I cant see much. I also checked the sway bar links and everything to see if its loose.
I have no idea what this is, any ideas?
Old Sep 8, 2013 | 08:20 AM
2003AP1's Avatar
Check the brakes, maybe a shim is not seated correctly. Might not be your issue, but its an easy place to start.
Old Sep 8, 2013 | 03:13 PM
Mark355's Avatar
Probably already checked this, but all the lugs torqued properly?
Old Sep 8, 2013 | 05:43 PM
mlc's Avatar
mlc
Are you sure it is the front wheel? These cars are prone to have the rear wheel bearing or bearing and hub go bad and it does make a clicking noise. Have you done the axle nut retorque yet?
Old Sep 9, 2013 | 05:37 AM
realblag's Avatar
something stuck in the tire?
Feuerrader
Sep 24, 2012 12:43 PM
DangerZone9K
Sep 10, 2012 12:11 PM
bkowa092
May 27, 2011 11:51 AM
allstar71
Nov 5, 2010 03:23 PM
Quivers
Dec 29, 2005 05:58 PM
