Whats the material?
Old Jan 11, 2006 | 12:59 PM
doorman's Avatar
Default Whats the material?
Just took mine apart and it all fell/crumpled out.
Old Jan 11, 2006 | 02:25 PM
Slows2k's Avatar
Don't know what it's made from, but it's part of the heat sheild. It's pretty common for it to break loose.
I wouldn't worry with it much, as the outer sheild is still in place.
Old Jan 11, 2006 | 03:40 PM
slalom44's Avatar
Top Answer: 1
I'm not familiar with the setup of our cat, but I was involved in the development of catalytic converters on other cars. They would typically use an "intumescent mat" as a filler when it is used. Its purpose is to act as an insulation blanket, preventing the heat from escaping to the surrounding area. Intumescent Mat is a ceramic fiber mat similar to fiberglas, but with much higher melting temperatures. It is also used on the inside of cats between the shell and the substrate.
Yes, it would fall apart because after it is installed, its strength is not important. Once it gets cured (from heat), it becomes relatively brittle.
ben5560
Sep 25, 2016 12:57 PM
AstroPhsx
Jun 26, 2016 08:20 PM
Chuck S
17
Feb 15, 2015 03:16 PM
TheRook
Feb 26, 2014 06:38 PM
