Wheel bearing vs Output shaft bearing
So I'm hearing a grinding/whining noise from the driver side rear wheel starting about 20-25mph. I'm pretty sure it's the wheel bearing since the noise doesn't change when coasting in neutral or when it's in gear. The only odd thing is that it grinds/squeals more if I turn left. It's actually reduced when I turn right, which seems odd since that would load up the driver's side wheel. Anything else I need to look for as a potential source? Fingers crossed it's not the output shaft.
EDIT- This noise is only after the car is warmed up.
EDIT AGAIN- Here's a video after the car is warmed up. Clutch in and down hill.
https://youtu.be/EWmTPmqAnbo
Does the noise change when you apply the brakes?
Output shaft bearing will be completely dependent on speed alone. It should not change hardly at all when cornering, applying the brakes, clutch in/out, high or low revs. It's about the speed that the car is moving. It should increase in frequency/loudness the faster the car is moving.
Sounds like a wheel bearing.
Replaced rotors, brake lines, pads, and driver's side wheel bearing. Still making the same noise.
Again, it's a squeaking noise that sounds rotational. Clutch in or out at low speeds.
