When to change fluids?
Old Jan 9, 2006 | 05:51 PM
Fasttimes!!'s Avatar
Default When to change fluids?
When do I change the tranny and diff fluids? What mile increments??
Old Jan 9, 2006 | 05:52 PM
04RioS2k's Avatar
first 10k miles should be sufficient for the differential fluid because of the break in period so you'll get rid of all the metal shavings.....transmission fluid I'm not sure as I changed mine out at 16k and I swear it was as clear/clean as it came from a new bottle itself....
Old Jan 9, 2006 | 08:32 PM
xviper's Avatar
The maintenance schedule outlines the interval for tranny fluid. Go take a look. Although I consider it to be a bit on the extended side, as long as the tranny works OK, I see no reason to do it any sooner. However, it's cheap enough and easy enough to do that I do it once a year anyway.
The diff fluid, on the other hand is not so clear. This is encompassed into the catagory of things to "check" annually. I do this one every year also. For those who track the car, it would be wise to change it more often.
While the diff fluid can take quite a beating, the tranny fluid can stay relatively clean for a very long time. However, this doesn't necessarily mean the additives are still viable.
Old Jan 9, 2006 | 09:06 PM
S2kracka's Avatar
I changed my diff and tranny fluids for the first time at ~10k and will do so again when it comes out of storage in the spring (24k). I plan on doing both annually due to the low-cost of each and how quickly it can be done.
Old Jan 10, 2006 | 09:07 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
I do it (tranny and diff.) every second engine oil change.wich,in my case,is once a year. ;using Redline Mt-90 for the tranny.,and 75W90 gearl oil for the diff.
Old Jan 10, 2006 | 09:16 AM
jdmgpw04's Avatar
Engine oil 3k royal purple , tranny 20k gm synchromesh friction reduction, diff. 15k mobile one it works great for me thats just me everyone is different
Old Jan 10, 2006 | 10:10 AM
Wisconsin S2k's Avatar
royal purple is crap for what they charge for it
Old Jan 10, 2006 | 12:17 PM
Way too expensive,for what it's worth;try Amsoil.!!!
Old Jan 10, 2006 | 03:24 PM
jdmgpw04's Avatar
why do you guys say that have you tried it compare to mobile 1 just curious i have tried both thats why i ask ? i might change to amsoil for the engine ?
watchdogd
Sep 6, 2009 06:36 PM
Tuanster
Dec 18, 2006 03:06 PM
vteconly
Apr 2, 2005 09:36 PM
padraf
Mar 15, 2005 05:24 PM
