When to do valve adjustments?
Just do it yourself. Its very simple, and there I dont see how you can do it wrong if you just follow the instructions. I've done it 3 times so far and I have never had a problem doing it.
This is just me, but I don't let anyone work or do anything on my car unless completely necessary (i.e. an alignment).
I know some people that have taken theirs to the dealership, spent $100 or so on the adjustment and they didnt even do them right. The people ended up doing it themselves and wasted their money. I would try to give it a shot by yourself man. If you feel like you can't do it, or cant do it right, go ahead and take it to the dealer.
If you are unfamiliar i would suggest not doing it. i consider the correct way to adjust valves to be something of practice and experience.
Many times i have had to correct issues cause by someone trying to adjust there valves. to tight andf you could create misfire,compression type issues. to loose and possibler noise, compression issues etc.
I say find someone experienced or go to the dealer. wouldnt want you to have more hassles than needed. just my $.02
It's been a while, but when I purchased my S2000 (about a year ago), I was surprised that Honda recommended 100k for the valve adjustment...
I had an integra in the past, and I believe they recommended every 30k or something like that... and the S2000 revs higher than the integra.
I guess maybe due to the difference in design?
Originally Posted by s2k dre,Oct 23 2010, 10:18 AM
I did my adjustment at 42k and my second at 80k and now i have 130k. Every time i did the valves they were barely out of spec.
I've done mine 2 times as well and have just shy if 130k. I think I made one small adjustment on the second check.
All of these short interval valve adjustment comments throughout this site kill me. I pass through 6k and have bounced off the rev limiter numerous times. Knowing how this engine is built, and doing a few check myself, I would agree with Honda that 100k is fine.
Why throw money away and/or take chances of breaking something that isn’t broke? I’ll never understand. I think we all need to start pulling the oil pan and checking rod clearances. We might need to start opening up the differentials to check …
If you tend to over-rev by a miss shift you best be adjusting things other the valves.
