Where to place a floor jack?
What are the best locations under the S2000 to lift it up with a floor jack. I'm looking for front and rear locations for things like tire changes, etc. I know from experience, some things that look strong end up bending, so I thought I'd ask before I need to do this. Thanks.
Bill
Bill
Using a floor jack on the side jacking points will cause indentations in the metal. This can be minimized by putting a rag on the floor jack cup. However, this happens on almost every car when you use a floor jack on the side jacking points. This doesn't bother me as I use the same indentations every time. If it bothers you, then use the central rear and front jacking points as suggested in the owner's manual. They also recommend the use of a rag.
What page of the Owner's Manual are you finding the information for the center front and rear jacking points? I found the info for the side points, but not the center points. I have a 2001 manual, and I couldn't find it anywhere. (I know where the points are, but I just couldn't find the page in the manual). Maybe my manual is missing something...
[QUOTE]Originally posted by Uncle Fester
[B]
Legal Bill: If you look at the beam that runs underneath the engine, you'll notice a reinforced piece of metal welded to the beam, that's your front jack point.
[B]
