Whistle AP1
Old May 29, 2025 | 02:33 PM
christianorizabal's Avatar
Default Whistle AP1
Pretty hard to hear but does anybody know what is causing this whistling sound?
https://youtube.com/shorts/x0WOBqJZUzw?feature=shared
Old May 30, 2025 | 07:30 AM
spider2k's Avatar
Active Streak: 30 Days
@Billman250 need your magic ears
Old May 30, 2025 | 07:38 AM
Car Analogy's Avatar
Sounds more like a high frequency ringing, not a whistle. So like something vibrating. Something light, like exhaust heat shield.
Poke around with pressing something against various places under hood, to immobilize whatever might be loose and ringing. Start with exhaust heat shields, working down to cat area. Shields around exhaust, shields attached to body.
Also try the large, black battery heat shield.
Then proceed to anywhere you can see or think of. Experiment.
It could also be a serp belt pulley bearing. Easy to rule out, just remove belt, see if issue goes away. Don't even need to remove belt, just undo belt from, say, water pump pulley, so its loose.
Old May 30, 2025 | 10:19 AM
spider2k's Avatar
I was thinking pulley as well, but the tct and valves are drowning it out.
Old May 30, 2025 | 03:28 PM
windhund116's Avatar
Originally Posted by spider2k
I was thinking pulley as well, but the tcg and valves are drowning it out.
I guess remove the serpentine belt and see if the noise goes away.
Old May 31, 2025 | 02:17 PM
it sounds internal to the motor with a stethoscope
freq
Oct 17, 2006 04:41 AM
03 9g
Mar 27, 2005 05:03 PM
