why does my car pull
any luck? im having the same problem ,i bought 4used tires the other day and it started to pull on acceleration so i went and got a alignment and that still didnt solve the problem also checked the tire pressure made it even all the way around im dumbfounded as to what it can be
They haven't swapped any of your wheels around have they? Just a question, but also make sure your rear tires are the same size and your fronts are the same size, I would check that tire that got plugged for a shifted belt or anything or check where the plug is if it is leaking, generally the overall condition of that tire
If you have a pull on acceleration, it is almost guaranteed to be the tires.
Brand, age, size, pressure, and wear must be the same. One tire may also suffer damage that cannot be seen causing the pull.
If all this checks out, note which way it pulls, then switch rear tires left to right to confirm. See if it pulls in the opposite direction.
Too much air pressure?
