Is it a differential problem or just alignment?
Old Jun 9, 2002 | 08:30 AM
njs2k's Avatar
Default Is it a differential problem or just alignment?
Ok, I need you feedback.
Suddenly, since two days ago I started to notice a problem in my '02 S2000.
I am going straight in the car, when I hit the gas the car starts to move to the right (a little bit). If I release the gas the car tends to keep straight ( as it should be). For instance, If I'm in the highway and hit the gas, the car moves to the right lane at the regular rate we change lanes on the highway. It is kind of a throttle steering.
The car feels very unstable in the highway . . It only has 3600 miles.
I don't think it is an alignment problem.
Your comments!
Thank you!
Old Jun 9, 2002 | 09:29 AM
DouglaS2000's Avatar
First and most simple thing to check... tire pressure. Make sure both sides are at an even 32 psi cold. If either one of your tires are low on air, it can cause the problem you described. I had the same thing happen to me. Low and behold, I had a nice large screw in the tire from which air was slowly leaking..
Old Jun 9, 2002 | 11:26 AM
njs2k's Avatar
DouglaS2000:
THANKS A LOT!
I just checked the tire pressure, and realize that RR tire was at 10 psi and LR tire at 30 psi. I run 36 psi at the front wheels and 32 at the rear. This is an advice that I took from this forum to make the steering feels and act quicker.
Best Regards!
Old Jun 10, 2002 | 11:59 AM
MarkS2K's Avatar
OMG!!! 10 psi is really low. Make sure you don't have a leak in that tire.
Old Jun 10, 2002 | 05:18 PM
scottrnelson's Avatar
A difference in rear tire pressure or a new rear tire and an old rear tire will make the car pull one way or the other when you accelerate or decelerate.
I blew a tire at 2500 miles and lived with a minor pull until all the tires were worn out 8500 miles later.
Then I experienced the low pressure case 300 miles after I put the new set on. Unfortunately, I had run over a 1/4" diameter screw and it came out while I was on the freeway, so the tire was completely flat before I could get off at a safe point. At least I was able to buy just one new tire to replace the shredded one and still keep good handling.
If I ever notice my car doing that again, I'm stopping immediately so I can find out what's wrong before wrecking another $200 tire!
s2khac
May 22, 2008 04:51 PM
s for shweet-2k
Oct 2, 2007 09:50 AM
Pitcru
Sep 30, 2007 09:19 AM
s2000from canada
Feb 19, 2006 09:50 AM
kuni
Dec 6, 2003 01:19 AM
