why is there an extra compartment in the intakebox
Old Nov 6, 2007 | 09:44 AM
G2k's Avatar
G2k
Default why is there an extra compartment in the intakebox
when taking the lid off the intake box under the filter there is hole holding a smaller compartment. what purpose does this serve?
Old Nov 6, 2007 | 10:37 AM
jzz30's Avatar
noise supression. if you cover it the intake gets a little louder
Old Nov 6, 2007 | 09:58 PM
G2k's Avatar
G2k
is that the same function as that wall inside the intake separating the filter?
Old Nov 6, 2007 | 10:09 PM
jzz30's Avatar
probably
Old Nov 7, 2007 | 02:21 AM
agent's Avatar
the wall increases airflow speed, as i understand. not the wall itself, but the small opening leading to the main chamber
Old Nov 7, 2007 | 02:42 AM
jzz30's Avatar
but what good is air flow speed through an opening only to be slowed down by a filter? i say take the berlin wall down and make some noise!
Old Nov 7, 2007 | 06:20 AM
jezzder's Avatar
airflow up, pressure down...
makes breathing through the filter easier
Old Nov 7, 2007 | 06:37 AM
Doug1627's Avatar
The wall at the beginning of the air path is to prevent hydrolock.
Old Nov 7, 2007 | 07:53 AM
TrackStar's Avatar
To smuggle drugs
Old Nov 7, 2007 | 08:19 AM
agent's Avatar
it creates an area of high pressure in the fron of the airbox, and lower in the filter compartment... thus the air speed from high pressure zone to low pressure zone increases
at least that's what i think
