Will My Coolant Kill My Engine?
Old Mar 11, 2006 | 11:23 AM
jaws4096's Avatar
Default Will My Coolant Kill My Engine?
I recently changed my coolant with Prestone. I had a total brain fart and forgot that the engine needs Type 2 coolant. Am I going to corrode my cooling system, or am I okay? How can I tell if a coolant is safe?
Thanks!
Old Mar 11, 2006 | 01:43 PM
cdelena's Avatar
If you full drained the old it will be fine.. it is just mixing that can sometimes create problems. I use Prestone extended life coolant in both my cars.
Old Mar 12, 2006 | 02:54 AM
INDYMAC's Avatar
Why did you change the coolant? I believe the owners manual says not to change the OEM fill for 10 years/120K miles. Were you having a problem with your cooling system?
Old Mar 12, 2006 | 10:06 AM
PilotKD's Avatar
I believe the owners manual says to only use Honda coolant because off the shelf coolant can damage the cooling system.
2004TurboS
Aug 15, 2017 12:31 PM
beefystud
Feb 20, 2015 08:30 AM
TougeS2k
Mar 26, 2013 10:41 PM
Opie Oils
Mar 2, 2011 05:45 AM
PathNull
Aug 8, 2005 02:53 PM
