Windows and Top wont work...
Old Oct 4, 2010 | 12:23 PM
  #21
HiRpmVTEC's Avatar
check red 7.5 fuses underneath steering column, left side
Old Oct 5, 2010 | 06:30 PM
  #22
JesusGLS's Avatar
Ill have dat check tomorrow haven't checked dat fuse under dash yet....any other sugestions????
Old Oct 7, 2010 | 07:16 AM
  #23
JesusGLS's Avatar
Old Oct 7, 2010 | 08:06 AM
  #24
aeonracer's Avatar
http://www.hondaautomotiveparts.com/auto/j...NIT+%28CABIN%29
You need component #10:
86500-S2A-A01 CONTROL UNIT, SOFT TOP
This recently happened on my friend's S2000 (also a 2002). The unit controls both the passenger window and the convertible top. Sucks but the control units have been known to go bad from time to time.
Old Oct 7, 2010 | 08:48 AM
  #25
JesusGLS's Avatar
Well on mine both windows and top stoped working.....could this be the problem???
Old Oct 7, 2010 | 09:30 AM
  #26
aeonracer's Avatar
If you really want to know, then grab a multimeter and a repair manual start checking voltages. Otherwise, you're just going to have to play guess and check. Everything you've said, and having checked all the relays and fuses, it sounds like the convertible top controller.
Old Oct 7, 2010 | 11:33 AM
  #27
ShiftGearAP1's Avatar
Hopefully these will help...
Old Oct 7, 2010 | 11:30 PM
  #28
Seattle2k's Avatar
Originally Posted by gh0St2K,Oct 1 2010, 11:39 AM
don't have any experience w/this but it did raise a good question in my mind. if your top gets stuck up or down (with down being more of an issue i guess), is there any way to manually get the thing up or tucked back down without screwing up anything?
Yes, read your owner's manual. There's a grey connector under the dash on the passenger's side. Mine was taped to the harness. Remove tape, disconnect connector, get somebody to assist you with manually raising the top.
The OP might want to double-check this connector.
Old Oct 18, 2010 | 03:09 PM
  #29
JesusGLS's Avatar
Old Oct 28, 2010 | 07:35 AM
  #30
JesusGLS's Avatar
PRedS2K
Mar 14, 2012 11:22 PM
Austblue
Jan 25, 2005 03:05 PM
