Windshield defroster not working
Old May 22, 2017 | 04:59 AM
s2kdarren's Avatar
Default Windshield defroster not working
unfortunately my front defroster is nonoperational. I put the setting to the windshield defrost mode and I can hear some action near the vents (it appears to move) but All air gets redirected to the main vents. No matter what setting i put it to it wont come out the windshield vents. any suggestions on what to do from here?
Old May 22, 2017 | 06:52 AM
Car Analogy's Avatar
When you turn on Defrost, it turns on the AC at the same time (unless you did the Modifry mod to disable that). So if AC is off, and you switch it to Defrost, does AC indeed activate automatically?
If it doesn't, then it seems the system doesn't realize Defrost was selected. Sounds like a switch problem. If it does, then it seems like its a duct problem, something mechanical that is preventing duct valve from actuating.
Old May 22, 2017 | 05:02 PM
Halfassjack's Avatar
Check out mode control motor.
Old May 24, 2017 | 10:38 AM
s2kdarren's Avatar
it thinks its functioning normally if i look under the drivers seat it also seems to move. is the only way to get to the ducts is by removing the dash?
Old May 27, 2017 | 09:31 PM
s2kdarren's Avatar
this is an uncommon problem based on my search so i wanted to post my solution in case anyone finds this thread. after 3 mechanics looked at it and couldn't find out whats wrong (i thought i was going to have to take apart the whole dash) my audio guy took a peek under the dash by the driver foot well and realized the flap was moving but wasn't turning all the way because it wasn't popped into its gear correctly. 20 mins later after some fiddling. problem fixed.
Old May 28, 2017 | 06:42 AM
Thank you so much for coming back with the solution. I'm sure it will be helpful to someome down the road with same problem.
Any more details on what the fiddling involved? How could he tell visually that the gears weren't engaged? What needed to be disassembled to perform the fix?
Old May 28, 2017 | 12:14 PM
s2kdarren's Avatar
So i didn't get under there to look. but apparently there's a flap under the dash near the driver side footwell. that goes back and forth to direct airflow. the flap was going back and forth but wasn't swinging around back to go to defrost mode (this was what I was told) its on a gear that rotates and it was off that gear so he popped it back on. apparently i had a control module under there that wasnt secured so it must have knocked it off. Im thankful it was such a simple solution. i was ready to rip the dash apart.
Nobody
Sep 5, 2016 06:36 PM
s2kdarren
Apr 28, 2016 01:24 PM
S2K Al
Nov 11, 2013 08:33 AM
BaysS2k
Apr 1, 2011 06:20 PM
BaysS2k
Mar 26, 2011 03:43 PM
