Winter shifting help!
Old Feb 3, 2004 | 11:48 AM
heffergm's Avatar
I'm looking for advice from folks who drive their cars daily in sub-freezing temps.
The issue I'm having is that, in the morning, the car is next to impossible to get into gear. I was thinking perhaps a good synthetic (i.e. Redline MT-90) would alleviate this, but everything I've read here about MT-90 says that shifting is actually WORSE with MT-90 than with Honda MTL when cold (which makes no sense to me).
Any cold weather folks care to make a trans fluid recommendation to help with my cold weather woes ?
Old Feb 3, 2004 | 12:02 PM
sirrach's Avatar
if I let the car warm up some, it's never been an issue even in sub 0 degree weather.
Old Feb 3, 2004 | 12:45 PM
Gernby's Avatar
Former Sponsor
MT-90 is REALLY bad when cold. MTL would probably be better, since it is lighter weight. However, I just switched to GM Synchromesh Friction Modified, and it is friggin' awesome! I have tried Honda MTF, GM Synchromesh (regular), MT-90, MT-90 mixed with MTL, and GM Synchromesh Friction Modified. I am not sure how GM Synch FM will be in the summer, but it is DEFINITELY the best I've used in the winter. This is the longest I've gone without a 2nd gear grind, and it is very smooth cold. I was also impressed with how well it did under heavy autocross conditions. I spent 36 minutes doing 25 autocross runs on Saturday, and it was perfect all day. It even warmed up later in the day, and I did 16 consecutive runs.
Don't be fooled by my "Dallas, TX" location. It gets down into the low 20's here too.
BTW, I am going to do a track day this weekend. I will do a write-up on GM Synch FM after.
Old Feb 3, 2004 | 01:34 PM
RazorV3's Avatar
im very tempted to try this GM friction modified, but some have complain that it breaks down too quickly. anyways, honda mtf feels the same as the first day i put it in. its not super smooth, but i like how the shifting characteristics do not deminish after time.
Old Feb 3, 2004 | 02:04 PM
afetsman's Avatar
GM Synchromesh is what I use...we just had 22 days below freezing (a new record here) with a few days below 0 (farenheit) and I have never had a problem shifting...
Old Feb 3, 2004 | 02:35 PM
xviper's Avatar
I have plain old Honda MTF in my car and have started the car up after having it sit outside overnight at near -30*C. Letting it run for about 2-3 minutes in neutral while I go out and unplug the car, scrape off the windows and brush off any snow, I simply put the thing in gear and go. It has never been difficult to put into gear. Something is not right with your cars.
Old Feb 3, 2004 | 03:09 PM
Gernby's Avatar
Former Sponsor
It isn't that Honda MTF is bad when it is cold, as much as it is that it sucks when it is hot. I liked Honda MTF for daily driving, but I would grind into 2nd every ~700 miles. I found that GM Synchromesh (regular) was a bit better than Honda MTF, but it still couldn't handle autrocrossing in high temps. I never was able to do an autocross without getting AT LEAST a couple 2nd gear grinds. Honda MTF was MUCH worse. It was a challenge just to get a single autocross run without grinding. GM Synchromesh Friction Modified has been perfect in EVERY situation so far this winter.
Old Feb 3, 2004 | 05:32 PM
Road Rage's Avatar
GM Tranny fluids:
Part 10-4005
88900332 General use
Part 10-4014
88900399 Syncromesh FM (for NV1500 trannies)
Semi-synthetic
Friction modified was designed for a truck transmission.
Old Feb 3, 2004 | 05:40 PM
jankemi's Avatar
I'll bet you've got a problem other than fluid. I've not driven in sub-zero F weather with my S2K yet, but on the 10 other manuals I've owner I've not had problems at any temperature above -25F or so. Below that, maybe, depending on the vehicle.
Is the problem N-> 1, or 1->2?
Clutch not releasing all the way?
--Mike
Old Feb 3, 2004 | 05:43 PM
Road Rage's Avatar
[QUOTE]Originally posted by gernby
