Wires from Vacuum Switch Shorted
Old Apr 30, 2006 | 02:00 AM
530s2k's Avatar
Default Wires from Vacuum Switch Shorted
Installed CTSC yesterday, drove around for about 4 hours- no issues. Check engine light comes on, ok... Don't have any tools, check under the hood for anything obviously amiss, looks good- decide to limp it home.
En route, EPS light comes on and power steering starts working intermittently.. Think maybe ignition cycle will bring it back, turn car off, try to crank, no juice. Roll start the car, car starts, turn on headlights, all interior lights dim.
Park car... Pop hood, see that the two wires (red / black) that go to the vacuum switch that's mounted on the vacuum resevoir thing (with CTSC) rubbed up against pulley and are shorting each other... Ok... Isolate with tape, hook up jumper cables- car fires right up. Unplug cables, car dying again...
So I've got a charging problem OR a completely dead battery (but I think charging problem would supercede) OR that short melted something else....
Plan right now is to permanently fix those two wires in daylight, borrow code scanner from Autozone and see whats up.
Any suggestions?
Thanks!
Old Apr 30, 2006 | 12:36 PM
530s2k's Avatar
Fixed the wires, checked all fuses, 15a fuse on ACG popped.
Car runs awesome again.
kpfdeezy
Mar 3, 2014 04:00 PM
stwokayyy
Jul 24, 2011 08:21 PM
DDonovan
Dec 8, 2009 08:58 AM
NFRs2000NYC
Jul 21, 2008 03:08 AM
