wiring issues?
Old Jan 27, 2009 | 12:12 AM
red 2000 s2k's Avatar
Default wiring issues?
ok i have 2 problems that i need some help with. 1 ill be driving down the road with my heat on and the radio almost all the way up and my radio will cut out. ill turn the radio off then turn it back on and it will start playing again. then like 5-10 mins later it shuts off again WTF. now #2 the reading lights that are right by the rear view mirror will not come on when the door opens no matter what the little light switch is set on. sooooooo do you guys think that is may just be some lose wires or maybe blown fuses. i dont know and you guys know 2 heads are better than 1 so if you guys can give me some opinions on what you guys think it may be, it would help. thanks
Old Jan 27, 2009 | 12:15 AM
ahrmike's Avatar
'check ALL of your relays. I had two bad relays in one shot. It could be just my car or it could be all s's that sit unused for a while. I changed 100's of dollars worth of parts before I found out it was a 5 dollar relay.
Old Jan 27, 2009 | 01:24 AM
yea thats why i asked here before i started spending. it helps with eliminating stuff. lol but yea i was thinking fuses and i didnt even think about the relays. im just gonna changed all of the relays and fuses (mid as well) tomorrow and see if that fixes it. thanks man
Old Jan 27, 2009 | 09:47 AM
ahrmike's Avatar
Yeah, let me know if you need the FSM. It helped a lot when I was tracing back the wiring.
Check the radio wire/ground behind the deck, and try check for corrosion on the top lights. the top lights get water in them if the seals at the top arent working right, and they just get all corroded.
Bmann
Feb 19, 2017 04:51 PM
Antonio'S2K
Aug 25, 2010 03:37 AM
mhdelano
May 9, 2009 09:14 PM
S2Kmonkee
Apr 5, 2009 02:07 PM
S2k001
Jul 3, 2003 02:26 PM
