A Word to the Wise
Old Sep 17, 2003 | 06:26 PM
boiler's Avatar
Default A Word to the Wise
Just wanted to share a recent experience. I replaced the OEM oil pan drain bolt with a magnetic bolt and it came with a hard nylon washer that I used. I was very lucky that I changed my oil when I did....the drain bolt was not much more than finger tight. This is the first time that I have had this problem and it is also the first time that I didn't use the Honda aluminum washer. I always torque the bolt down, so the only answer is that the washer allowed the bolt to work loose.
I forgot that this engine isn't just any old engine. The 9,000 rpms take their toll in many ways. Just be careful.
Bob
Old Sep 17, 2003 | 06:46 PM
fly_S2K's Avatar
What type of magnetic drain plug did you use? I purchased the Spoon magnetic drain plugs and it came with aluminum washers.
Thanks for the word of warning.
-Johnny
Old Sep 17, 2003 | 06:54 PM
boiler's Avatar
-Johnny
I found a magnetic drain plug at Pep Boys and it came with the nylon washer. It has the OEM washer on it now. I just checked it several weeks after changing the oil and it hasn't loosened up with the Honda washer.
Old Sep 17, 2003 | 07:33 PM
Voodoo_S2K's Avatar
Two words "safety wire".
Old Sep 17, 2003 | 07:43 PM
boiler's Avatar
That should work. I haven't used safety wire since the Air Force in 1966. I still have a roll in the garage, though.
Old Sep 17, 2003 | 07:47 PM
Voodoo_S2K's Avatar
Old Sep 18, 2003 | 03:29 PM
boiler's Avatar
Whose oil filter is that?
Old Sep 18, 2003 | 03:30 PM
Voodoo_S2K's Avatar
[QUOTE]Originally posted by boiler
Old Sep 18, 2003 | 03:36 PM
boiler's Avatar
[QUOTE]Originally posted by Voodoo_S2K
Old Sep 18, 2003 | 03:38 PM
Voodoo_S2K's Avatar
